BIOS 2101 Question - Need help from 2101 useres...
xcite
Greetings everybody!
Because of constant restart and power looses I was froced to flashback BIOS from 3202 to 2101.
And after this flashaback restarts and power looses seems to be gone - 3 days already of stable working.
But now i have another problem:
In 2102 BIOS under "Advanced" > "PCH Storage Configuration" option "Hot plug" for "SATA6G_7" - "SATA6G_10" had dissapeared !!!
For "SATA6G_1" - "SATA6G_6" it is active.
I've read the manual and it says that for "Hot plug" the "AHCI" must be enabled for correspopnding SATA Controller. It's enabled, but "Hot plug" is absent...
Can someone take a look to your 2101 "Advanced" > "PCH Storage Configuration" ? Is "Hot plug" option available for "SATA6G_7" - "SATA6G_10" ?
Thanks in advance guys!
Arne_Saknussemm
Level 40
I'll take a look when I get home...if someone else doesn't get you the info first...:)
EDIT: No, hotplug is not an option on those ports...
Yeap, just installed 3009, and "Hot plug" is available there for all SATA6G_x ports (1-6 & 7-10)...
Seems to be that in 2101 and earlier this option does not exists...
