asmedia asm104x usb 3.0 host controller not found
Karlsap
I just did a fresh windows install 8.1 64 bit and when I am install asmedia usb diriver it is giving this error messaage "asmedia asm104x usb 3.0 host controller not found". I used the same driver many times without havviinig this problem. In bios the setting for the controller is also enabled.
Any ideas?
Chino
Level 15
Chino wrote:
Have you always been using Windows 8.1 and that exact same driver?
Yes. I shutdown down the pc an re-installed windows with the same driver and now it found it.
