Also Having USB issues.
NuMetal93
I saw that there was a different post about USB related issue but, my issues is quite different then his. My issue is that the last tow USB 3.0 ports on my Rampage V Extreme (ports 9 and 10 in the manual diagram) shut off and do not detect devices. If I download the USB drivers off the ASUS site they work until the next reboot. I am not shur if it is related to me being on the 0007 Beta bios. When the ports aren't responding it dosent matter if its a keyboard mouse or USB flash drive, it still wont register. Any help would be greatly appreciated.
Specks:
Asus Rampage V Extreme motherboard
Intel Core i7 5930K cpu
Corsair vengeance plx ddr4 ram
Sli Nvidia gtx 770 (EVGA)
EVGA supernova 1300 g2 power supply
19 REPLIES 19
spamhead
Do you have anything else plugged into your system USB 9,10 are shared ?
41865
Obsidian 800D Case
Rampage Extreme 5 X99
Intel i7 5960x Extreme Edition
Corsair H100i Cooler
Corsair Dominator Platinum 16G 2800 MHz
Samsung XP941 512 GB (Boot)
2 x M500 SSD Crucial (Raid 0)
4 x WD 2TB (RAID 5)
2 x GFX 780 TI Kingpin (SLI)
Yes, 2 mice, corsair keyboard, headphones, cam, and a razer orbweaver.
41865
If i may ask how hot does your cpu idle with that h100I and did you get corsair link to work with it. I just hooked the fans into my motherboard cus link wont detect them?
Probably because the Corsair Link software doesn't work right on windows 8/8.1 have you downloaded the newest Link software i would of thought they would of fixed this problem by now was 8 months back i had the problem.
Chino
Level 15
Update to the latest 0705 BIOS using an USB pendrive and the EZ Flash Utility. When the process is finished, shutdown your system. Proceed to clear your CMOS.
Also which slots are you using for your GPUs?
slots one and three
NuMetal93 wrote:
slots one and three
If you're using the black slot for your second GPU, the two USB 3.0 ports beside the LAN port will be disabled. So you will need to use the other USB 3.0 ports or install your second GPU into the fourth slot which is the recommended slot for optimal performance when doing a two way SLI o CrossFireX configuration.
On the site i only see the 0603 bios but your reply has a link to the 0008 bios, which would you prefer me to use. Or I may be looking in the wrong place?
Chino
Level 15
Here you go: 0705 BIOS. Read my previous reply on the slots as well in case you're using the black slot instead of the fourth slot.
