AIDA 64 CPU Power Misread on 0901 but not on 0802
andy9999
Hi Rampage V extreme with 5960. On 0802 bios Aida64 shows power correctly at 100+ watts. On bios 0901 shows the power between zero and 1. Weird. Any ideas? Thanks
4 REPLIES 4
Praz
Hello
CPU related power monitoring is not possible if any SVID type settings are disabled.
Praz wrote:
Hello
Same here, it can cause overclock instability so it will disable itself if on auto, i leave mine enabled as I like to see the power draw of CPU and RAM.
andy9999
that cracked it thanks appreciate it
Praz
Hello
You're welcome. 🙂
