01-19-2016 03:18 PM - last edited on 03-06-2024 03:03 AM by ROGBot
01-19-2016 03:20 PM
01-19-2016 11:40 PM
01-19-2016 11:42 PM
01-19-2016 11:44 PM
Qwinn wrote:
The auto tune voltage is about right, may be able to go down a little but probably not a lot. If you hit 80c on a core in occt after 4 minutes, at only 1.3v (which is probably what you're really hitting on load), 4.4 is definitely the highest you'll want to consider for 24/7 with your current cooling. Never let cores go over 77 max, and don't let CPU package temp go over 80c sustained (very brief spikes up to 83 or so are ok). I'd recommend lowering your total adaptive vcore to 1.25-1.26 and setting input voltage at 1.9 and trying OCCT again, see how much of a difference it makes. Can also try Load Line Calibration 7 or 8, see if that helps (if you set it to 7, put input voltage as high as 1.95 as it will actually drop under load).
I'd be curious how your friend auto-tuned to 4.7 and what voltage that set him to. I'd be surprised if it wasn't set to a dangerous level at that speed.
01-20-2016 08:07 AM
01-20-2016 08:49 AM
01-20-2016 09:43 AM
Minsekt wrote:
whats your power plan? im idling with 28-31C @ 4.6ghz / 1.23vcore / 1.820 cpu input voltage and 1.0v vccsa
if im using high performance my temps are rising up to 40C in idle, when using balanced its downclocking the cpu to 1200ish mhz in idle and temps are dropping about 10-12C. ive just made 2 shortcuts for the power plans and put them on my taskbar.
01-20-2016 09:46 AM
