32gb vs 64gb, OC issues I should be concerned with?
djb
Hi!
I'm building (replacing my RIVE/GTX 680) a gaming machine for surround 3D. 3 X Asus VG278H, 3 X EVGA 980 Hydro Copper, with 5930K.
In a couple years, this will be changed over to a multipurpose pc, including video editing. Probably switch the cpu at that time.
I've read here that you should get a complete "set" of memory, if you plan to add more later, thus, from reading here, got the:
G.SKILL Ripjaws 4 series 64GB (8 x 8GB) 288-Pin DDR4 SDRAM DDR4 2400 (PC4-19200) Memory KitModel F4-2400C15Q2-64GRK, as per QVL.
The bulk of the OC will be on the gpu's.
I've also read here that a few games, like Dying Light, might be best to have 32gb instead of 16gb.
Thus, my question, if I do plan to do some nominal OC to the 5930K, will I be hindering the CPU OC much by putting all 64gb of ram in, instead of just 32gb?
Thanks!
I Love ROG 🙂
5 REPLIES 5
Chino
Level 15
Running 64GB will tax the CPU's IMC. Not knowing your CPU's quality, it's hard to say how high you can overclock.
Omik
I just finished testing my overclock with G.Skill F4-2800C16Q-32GRK ram. I'm currently at 127.3x34 which is roughly 4333.3mhz using 1.35 volt input. Correct me if I'm wrong, I assume that a 5930k should get 100-300mhz higher than my overclock since it has two less cores.
In a perfect world, yes. 😛
Only if it is a good sample. If it is an average sample it will be limited for frequency.
djb
Thanks guys, I guess I was asking the obvious, only one way to find out, start with 32 and see what happens! 🙂
I think I'll bench test with all the ram just to make sure I have a good set now, then yank 32 gb back out.
I appreciate all the contributions here, saves a lot of trial and error.
djb
I Love ROG 🙂
