05-17-2016 02:54 AM - last edited on 03-05-2024 09:48 PM by ROGBot
03-03-2017 11:22 AM
03-03-2017 11:31 AM
03-03-2017 12:15 PM
03-03-2017 12:41 PM
03-05-2017 01:38 AM
Arne Saknussemm wrote:
Clear CMOS
In Extreme Tweaker Tab
Set AI Overclock Tuner to "manual"
Set Dram frequency to 3000
Go into DRAM timing control and set primary timings for your RAM...( will look like 15-15-15-35 for example...read that off the sticks themselves leave the rest on auto)
Go into Digi+ and set DRAM current capability to 130% and phases to extreme for channels AB CD
Set CPU system agent voltage (vccsa) to 1.25
Set CPU input voltage (vccin) to 1.9v
Set DRAM voltage (vdimm) to 1.36 or 1.375 for AB/CD
Set CPU spread spectrum to disabled
F10 save and exit and see if that boots and if it is stable.
EDIT:
In Dram timing control you can also try setting "rampage tweak" at the top to "2"
03-05-2017 02:00 AM
rocafella1978 wrote:
*** UPDATE *** CMOS CLEARING DID THE TRICK, now i can make changes!
03-03-2017 07:39 PM
03-03-2017 11:27 PM
03-04-2017 10:50 PM
03-05-2017 12:00 AM
