Tuf A15 fan speed 0 rpm
Vedant1004
I recently Brought asus tuf A15 Ryzen 7 rtx 3050 . Yesterday I got an bios update from asus care. After the update I observed that the fan speed in the laptop on silent mode is going to 0rpm when the laptop is ideal and at that time when I switched it to performance then the fan speed increase and slowly decrease to 2000rpm and on silent it slowly goes to 0 rpm and the divice is on normal heat 65-70⁰ . Plz help [photo attached]
ddpppp
Sell the useless box and go for some other good brand laptop or desktop since ASUS is behaving wierd and seems to be working unethical via firmware and BIOS updates which are making end users device unusable or the keyboard or motherboard gets malfunctioned or dead after the update.
Seems like ASUS is hit with some kind of cyber espionage with some sort of deadly malware which is causing a lot of issues or ASUS is using the same tactics which some brand uses to make their end users device unusable after certain period of time via updates by slowing down the device or causing permanent damage to the device hardware via updates. Anyways a lot of people are affected and ASUS is completely unaware and not concerned about it. Over-all experience is really bad as it seems ASUS is not trustworthy.
