Zephyrus G14 2022 Mediatek Wifi slow after pluging in power supply
syntaxterror
Hi here,
somehoe my Wifi connection speed drops to half the speed, as soon as i plugin the power supply.
I already reinstalled the drivers, made an BIOS update and checked on Armoury Crate and Windows for any power management issues.
Any ideas?
1 ACCEPTED SOLUTION
Accepted Solutions
Thank you for the answer.
Dumping AC was a good idea, but it didn't really help.
What fixed it, was exchanging the wifi card with an Intel AX210 NGW.
Now everything is working pefectly for the first time.
M0NG0
Dump AC and use this https://github.com/seerge/g-helper
Should fix it when all bloatware is not sucking bandwidth
M⊕NG⊙
