ROG Zephyrus g14 GA401QM - my gpu fan broke and I need help with replacement
mazbii
So my warranty for laptop ended about 2 years ago and my fans broke. I had another problem liquid metal cooling that I managed to fix at the local service by changing it to termal paste. Now they said they can't help me with broken fan. I am looking to replace my fans or buy similar ones that would be compatible, but I don't even know how to verify their model. Could you guys help me out with finding a fan model that would fit my setup? If I need to add some details I will answer in the comments.
As for now I am still using the laptop but turned off the GPU and the GPU fan, but I really need to fix it. I don't know if this helps but:
GPU: RTX 3060 Laptop
Motherboard: GA401QM
CPU: Ryzen 9 5900
Power Supply: I am not an expert but it says A20-180P1A Input 100-240V 50-60Hz 2.5A Output 20V 9A 180W
Nate152
