ROG Zephyrus Duo 15 GX550LXS-HC045T - Heat problem
Walron
Hello Everybody,
Anyone have heating problem with Zephyrus duo too?
I try 3 power gen: Windows, Performance and Turbo.
The best I think the turbo because when it's active the fans' speed are the highest and the termometers show the lowest 85-95°C for both CPU and GPU. The fans in this case still not working on tha max level/rpm.
I have 2 problem:
* The laptop so hot I couldn't touch it, I got burns (I got blisters).
* After 5+ hour on, sometimes my GPU won't woking, like it turned to power saving mode. I have to restart it.
Any suggestions?
Thank You.
Gábor
0 REPLIES 0
