My GPU is stuck at extreme power saving mode in armoury crate
Infernus822
My dedicated GPU for some reason has stopped doing its job and it doesn't work. In task manager, it's always at 0% utilization and all the graphics work is being done by my integrated GPU. The name of my GPU has also disappeared from the top, in armoury crate. I have tried enabling and disabling the GPU in display adapters, reinstalling drivers, and resetting my laptop,  however, I haven't seen any improvement. Furthermore, I had my laptop checked for any hardware defects and they said that everything looked fine. Please help me resolve this issue.
23 REPLIES 23
Keogmar
I just fixed mine. It also wouldn't let me install an update on my Geforce driver. Kept saying not compatible with Windows all fixed and installed.
1. Go to Amoury Crate.
2. Change performance to Windows.
3. Unplug laptop and plug it back in. Started recognising gpu again.
4. Go back to turbo and it let me update the driver.
Hope this helps! 🤞
Sorry dude, I tried but it didn't work 😞 It might be cuz our laptop isn't the same. I have AMD graphics and yours is NVIDIA which might work differently. But I do appreciate your help! Thank you!
Ok so an update guys, i installed g-helper and for some reason my game is working normal all of a sudden which is good but I'm still not sure if it has completely fixed all my GPU issues....will keep on updating.
I can't believe that worked haha so random thank you
i saw ur cmnt and tried and it kinda made laptop smooth lol
hey.. i tried that but it doesn't work.. any other suggestions?
worked thx
MatthiasC208
Hey Infernus,
I think it is a problem with an update causing this.
Mutiple people already posted on the forums having the same problem, as do i.
After the latest update my armoury crate say's the GPU is in power saving mode, but on my adrenaline software i see it running.
Keep me updated if you have any changes!
So I am using this software called G-helper....it has shown me some improvements but my performance is not as good as it was. Maybe it'll fix your problem. Just google G-helper and it should take you to github where you can download it. Hope that works!
