Window 10 Sound Problems on Battery (GL702VI)
Setoka
So recently i upgraded to the windows 10 April update and noticed that when I'm on battery my speakers buzz for about 5 seconds when i get a notification from telegram or discord or any other app that does notifications it does not always happen only about 90% of the time ill get the annoying buzz
If I'm playing music or something when i get a notification the buzz comes and the music stops after the buzzing stops i have to start the song again and it all happens again once i get another notification
In task manager the RAVBg64.exe priority is set to below normal so i changed to to normal and above and that did not fix the problem
My sound drivers are 6.0.1.8302
Sonic Studio 3.6.24.474749
Win 10 -1803
Edit:
Faulting Application Path: C:\Windows\System32\audiodg.exe
Problem signature
Problem Event Name: APPCRASH
Application Name: AUDIODG.EXE
Application Version: 10.0.17134.1
Application Timestamp: c599a740
Fault Module Name: NAHIMICV3apo.dll
Fault Module Version: 10.0.10011.16384
Fault Module Timestamp: 595e4369
Exception Code: c0000005
Exception Offset: 0000000000379f91
OS Version: 10.0.17134.2.0.0.256.48
Locale ID: 4105
Additional Information 1: fe25
Additional Information 2: fe254ad5402c8dcdc505bca8ee5ca2f4
Additional Information 3: f535
Additional Information 4: f535e6e77c341522cd367e2a95194a80
Asus support also wants me to send it in for rma for a driver issue
Its already been in 2 times for other problems
This only started happening after the April update
If anyone knows how to fix this it would be greatly appreciated
Cheers
0 REPLIES 0
