Undervolting help for my gl502vm
mehul_mishra12
I have an ASUS ROG Gl502VM with i7 7700 hq and GTX 1060. It showed high temps while playing games like pubg upto 90C+. So i read on the forums that it was on of the persistent issues which requires undervolting so i decided to give it a try and oh boy did it exceed my expectations on GPU. The temps dropped from 80+ to 60-65 while playing PUBG. Oh boy and did the CPU break all the expectations the CPU did not drop the temps and instead started showing spikes of upto 98C on only 2 cores while the other two were atleast 20C below. After I turned off TURBO the temp spikes stopped but the temps were still high upto 88C. I need help on how to properly undervolt and need some help on what i m doing wrong. Attached is all my settings and the temps at idling which show spikes.
Please note- The temp spikes are only on 2 of the 4 cores. So the temp spikes are also due to these 2 cores.
CPUID- https://gyazo.com/ff1f33fcddcc1c3898c955de4ca9c44f
TS- https://gyazo.com/0536ff2f389bcfffdcca1b05120eb717
TS FIVR- https://gyazo.com/5526510e7f58f339108aa3f3d381eb20
Help me out
12 REPLIES 12
dasBOT
interesting ... thx i will test it
Kompensan
I hope I can help with my experience on this track to lower temps.
After so much testing. I discover that disabling Turbo via Windows Power Manager to 99% does not work as expected. It disables TURBO however temperature dropping is not high as expected.
The only thing which worked for me so far was disabling TURBO via Throttlestop on that option box but also disable the SpeedStep feature on the box at the right. Kept also the uV active by using -0.150mV for both Core and Cache.
Oh thanks. I didnt try the speedstep feature
