First and foremost, USB-C is a connector type, which can carry protocols such as Thunderbolt 4, Thunderbolt 3, USB 3.0, USB 3.2 gens 1x1, 1x2, 2x1, 2x2, and USB4. So, now you should be able to see why this does not make sense:
JoarS wrote:
"However I did not by (sic) this dock to connect through USB3.0. I want to use USB-C.
BTW, it looks like the link to your specific dock has expired, so your link just sends me to a list of 15 docks:
JoarS wrote:
This is the dock I bought and it's supposed to supply the computer with power up to 60W.
In any event, you won't be able to charge your laptop with only 60w, but your other USB peripherals could use this power to run or to charge. Sorry that I don't have enough context to help fix your problem, but this backgrounder should help you find the answer.
- mBrane
ASUS Rampage IV Extreme, Intel 3930K @ 4.4 GHz, 32 GB Corsair Dominator (liquid-cooled)
2xEVGA GTX 680 Hydro Copper @ PCI 3.0, Samsun Evo 860 SSD
Aquaero 5 Pro Controller w/ waterblock
7x120mm Thermochill Rads 7x120mm Gentle Typhoon 1850s
2xSwiftech MCP35X pumps w/ EK Acetal Dual Top @ 82.5 gal/h
EK Acetal+EN blocks on CPU, RAM, Northbridge, Southbridge, and VRMs
28c idle, 38c under load, nice and quiet!
