Scar II RTX 2070 screen problems, coil whine and Audio problems.
Ardilla_del_mal
Ok.
Long story short.
I purchased this on March 5
The screen its like this:
https://photos.app.goo.gl/QEkbUaq7DW8nvm2j7
It happens when you are on desktop mode, playing games etc...
You can even see weird green dots:
https://photos.app.goo.gl/gb1ecp4J2rcyrGSX6
It has coil whine:
https://photos.app.goo.gl/VFm14Q9rnnMWX7zq5
And the right speaker sometimes works and sometimes don't...
Any help?
Kevhahas
Hi, I'm having similar problems with my GL504GV screen where it will flicker 1 horizontal chunk of static and the image in the bottom region of the screen getting distorted, though mine happens quite randomly and somewhat rarely(3times a day). Was wondering if you've found any solution. I sent it in for repair once and they told me they replaced the display cable which was damaged during manufacturing but the problem still persists. Would really appreciate any information that you can share, thanks!
nlipchak
Ardilla del mal wrote:
Ok.
Long story short.
It has coil whine:
Any help?
Same problem here. Flickering randomly.
Could you solve the problem?
Best regards*
