Please help update problem, Gl703vm will not boot from usb
ArogGL702vmF
Hello, Install update from asustech on 6/2019. Gl703vm will not boot, from usb (came with purchase), or win10 rescue usb or jaspersky usb , or win defender rescue usb. Suggestions?
4 REPLIES 4
xeromist
**Moved to GL sub-forum**
FULLMETALJACKET
Level 11
Remove the SSD and downgrade the bios to the previous version.
raju2529
I have Kaspersky usb , it wont boot on uefi based , so dontworry.
but windows 10 64 bit only boots.
use rufus software make bootable windows 10 usb select mbr with uefi or csm mode.
goto bios ,
disable secure boot ,enable csm mode.
save and exit , insert usb pendrive , select boot device as usb pendrive
Intel i5 7200U_ Nvidia 940MX _Windows_11_Enterprise_64bit_22H2_buildno_22621.754
