[ISSUE] Sound playing through both headphones and speakers
Murtag
Hi, I noticed when i plug in my headphones into my computer, the headphones work but the speakers do not deactivate. I unplug the headphones and plug them back in, that deactivates the speakers temporarily but after a couple minutes the speakers activate on their own so I have to do it again. so I updated the drivers through support.asus.com that did not fix the issue. i muted the speakers and it mutes the headphones too so, i mute the headphones too and unmute them and the headphones work for a couple minutes and then stop working and i have to do it again. when i unmute the speakers, it all works, but it ALL works, the speakers and the headphones. so I have no real workaround except that i unplug and re-plug the headphones.
I'm about to start school within a week and I definitely will not have time to troubleshoot these sorts of problems. Any help with this problem will be greatly appreciated. Thanks.
21 REPLIES 21
xeromist
Try the most recent drivers from the realtek site.
dstrakele
Level 14
1) What model ASUS laptop do you own, @Murtag?
2) What version audio driver is it currently running?
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
I'm using a G75V, and I had hoped that the VIA audio driver version 6.0.01.60100 from the asus support site would fix this, although it hasn't.
Ayman
welcome to my world @Murtag :rolleyes: same problem for me still waiting VIA to fix the problem
Case: Corsair Obsidian 750D.
CPU: Core i7-7700K.
Board: Asus Maximus IV Formula Z270.
VGA: Asus Strix GTX 1080.
Ram: 32GB Corsair VENGEANCE LED 3000MHz.
CPU Cooler: Corsair H110.
PSU: Corsair AX860iW.
SoundCard: Creative Sound Blaster Recon3D PCIe.
dstrakele
Level 14
@c_man claims that issue is resolved with his settings in http://rog.asus.com/forum/showthread.php?20589-Via-Audio-Driver-v6.0.01.10800a&p=145905&viewfull=1#p.... There is also a new VIA driver release, version 6.0.01.10800a. You may as well give it a shot...
I recommend you reply to that thread and abandon this one.
Thank you, I'll give that a shot and see if this works.
c_man
Level 11
I have not seen once the problem with 10600a or 10800a and I use headphones daily. BUT, I did a clean install with 10600a. I don't know if updating those old buggy drivers is the reason why you still have this.
I downloaded 10800a and it still has not fixed the issue.
dstrakele
Level 14
@Murtag and @Ayman - you need to find out what @c_man is doing right to resolve your audio issues.
