01-04-2016 03:36 AM - last edited on 03-06-2024 03:11 AM by ROGBot
01-04-2016 06:02 AM
ROGKenny wrote:
Have you tried removing the battery? Then try with just ac plug?
01-04-2016 06:32 AM
Julskey wrote:
Have you tried removing battery and then press power button for more than 30seconds, then reinsert battery and press power on?
01-04-2016 08:09 AM
01-04-2016 08:18 AM
ATR-42 wrote:
this is very similar to how my G75VX meet its death. only in my case i could hear its fans turning. no other signs of life.
01-04-2016 08:24 AM
01-04-2016 08:32 AM
ATR-42 wrote:
blest,
unfortunately i didnt and it was totally out of the blue. i got the black screen, power on lights and fan noise ONLY... nothing else would function. if i let it sit for an hour or so, it would come back to life for about a minute or two, then just go back to black.
after looking around the internet it seemed to be a point of failure. i saw guys taking the whole laptop apart and "reflowing" the GPU (heating it to 200 degrees). in any event it was going to need service so i threw in the towel. I bought my G75 used so i was not in a good position for support. yours is new so at least ASUS should be backing you up with full repair.
01-04-2016 09:01 AM
