I bought an Asus Rog GL-753VE and it has terrible battery performance, like i set it to battery saver and watch some movie after 2 hours of watching the battery go to 28 percent, my display is set to lower, i disabled and keyboard light so brightness on rog acura is to zero, i dont have any other apps running except bsplayer where i watch the movie.
Second test i was writing a document in Office after 2 hours and 10-15min the battery go to 6% same "Battery Saver".
Third test is the gaming, i wanted to try gaming i launch a game Fortnite and it was so LOW FPS like in battery saver it was 10-15 and laggy, after i switch to Max Power it go to 80-100 and variable not stable, and it must be some lower performance to get 100 fps, idk what the performance in gaming is so low i also set the game in nvidia settings to be runned via gtx 1050 ti instead of integral graphic intel.. Also battery dies after 30-40 min of playing, that **** for me.
Also tried another game CS:GO it was same problem as Fortnite verry drop on FPS, but the performance of the laptop is great i mean the specs was so great i7-7700HQ + GTX 1050 TI my friend has I7-7700 on Desktop PC and GTX 1050 ROG he has 100 times better performance with same specs ?
The battery is like it cannot stay longer than 2 hours which is not good.
If you play game you can only 30-50min max.
I have warranty on the laptop but i wanted to ask first before i contact them.
