So I noticed my Laptop (GL702VMK) battery LED was flashing intermittently orange and not a solid green like it normally is. It was reporting 94% battery and "not charging". I unplugged it and fired up a game to try to drain some more juice and see if it would start charging once plugged back in. For some reason it just stayed at 94% no matter what. A quick web search and I found a post about holding the power button for 10 seconds after a reboot once the laptop entered the ROG splash screen. I did this and awesomely enough it seems to have solved the problem. After the reboot the LED is solid orange, reporting 74% battery and charging. Right now it appears things are going back to normal.
So I am guessing/hoping this is a power management issue and software related? Or does this not bode well for the future of my battery? Has anyone else encountered this and has it led to a battery replacement shortly afterwards? I have 3 months of warranty left and really don't wanna go through a possible RMA nightmare. Thanks for any help/information in advance.
StarJack
