11-26-2016 06:09 AM - last edited on 03-05-2024 12:26 AM by ROGBot
08-06-2019 06:29 PM
HolographicSun wrote:
Which paste do you suggest me to use? The one they used seems awful, I don't know what that is so I am unable to find the same one.
It never throttles, but that's what worries me 'cause it reaches 97°C easily, wish there was a way to manually throttle it, I prefer a loss in performance than my temps over 90°C. I know it won't die in a couple of days, months or years but I intended to use this laptop for at least 5 or 6 years and not just for gaming. I think the hardware (GTX 1060, i7 7700HQ and 16gb of RAM) will hold until then, but I don't think the CPU will last that much, or some other component close to it.
08-07-2019 08:17 PM
FULLMETALJACKET7 wrote:
They usually apply something like K5pro on the vrms and regular thermal paste on the dies. It doesn't matter which one you use, as long as it is some good quality paste. The thermal compound is not the weak link on this thermal solution, but rather the heatpipes and heatsinks. They're just too small. That's also why most of the times you see almost no improvement when using liquid metal on these things.
It will last a lot more than 5 or 6 years. My old Lenovo y510p reaches 97c on gpu2 after just a minute of gaming, and it's still running absolutely fine since 2013. Needless to say, it's completely obsolete for gaming today. It can barely run GTA5 (which has near perfect sli scaling) and it's totally useless for anything that doesn't support sli.
There's really not much you can do about it. Undervolt both cpu and gpu, raise the back of the laptop from the table, manually set the fans to 100% and repaste, since you already opened it. You could also underclock the cpu and gpu but hell, that would be like buying a 300hp sports car and putting a brick under the gas pedal. Makes no sense having the power there but not being able to use it, imo. In that case you would do better with a 1050ti laptop. Cheaper and runs cooler out of the box.
08-07-2019 09:34 PM
Thanks for the reply! I am not really experienced so Idk which one can be considered a good quality paste. Do you have any suggestions about it? Do I have to put a different paste on the vrms and a different one on the CPU/GPU? If so, why? Do I have to put it also on the heatsink? I am actually scared 'cause I never repasted anything and it was my first time opening a laptop this way.
Also do you think the factory paste you see in the picture is dried out? If so, could that be the reason of my CPU temps getting higher?
08-08-2019 08:24 AM
I would recommend Thermal Grizzly Kryonaut or Arctic MX-4. Any other name brand should work just fine though. As for the vrms, you can either use K5pro or thermal pads. K5pro is easier to use but not so easy to find depending on where you live. If you're going to use thermal pads, you have to measure the gaps between the heatsink and the components and buy the pads accordingly.
The paste looks fine as far as I can see, but don't mix two different types of paste like that. Clean it all up really well then apply new paste. If you decide to remove that protective plastic thing, be careful with the passive components around the die when cleaning. You can easily knock them off the substrate.
08-08-2019 06:12 PM
Thanks again! I ordered both the Arctic MX-4 and the K5 pro. Will update my temps after repasting (but I won't remove the plastic thing or use thermal pads). Have one last question though. I was checking some youtube videos and saw that many use the same paste for GPU/CPU and the vrms. Looking at the factory paste on my laptop looks like they also used the same kind of paste for everything. Do you think I can use the Arctic MX-4 on the vrms too? Or is the K5 pro really that better?
08-11-2019 07:58 PM
Regular paste on the vrms is not really ideal because usually there's a gap between the heatsink and the components. Regular paste isn't thick enough to fill that gap without dripping out over time. k5pro is more like a jello kind of thing.
From the factory it usually comes with k5pro on the vrms and regular paste on the dies. Don't even think about using k5pro on the cpu and gpu.
08-12-2019 08:50 AM
First off, thanks a lot for the help! I would have never take the courage to repaste without your advices.
Repasting worked pretty well. Gotta be honest, I did it twice. First time I wasn't satisfied with the result, as I was still getting my CPU up to 93°C with Forza Horizon 4. So I repasted again putting a bit more paste on both CPU and GPU. Now my CPU never goes over 81°C, it usually stays on mid 70s, so it's a huge -15°C difference. My GPU temp also decreased by 5-6 degrees, usually staying at low/mid 70s up to max 78°C on most demanding games. This is with CPU undervolt -125mv and a light GPU overclock (+215, +200). I also noticed what's being said in the first post. When the GPU temp increases CPU temps increase too. I forgot to say that my room temperature is 30°C, sometimes even a bit more (no AC), so I hope to get lower temps in the next months.
I am actually surprised repasting worked. Have one last question now: how often should I repaste? The Arctic MX-4 package says it can last for 8 years (but I doubt...). What about the k5 pro? Is there any negative effect of repasting too many times?
Btw I also noticed something weird on my CPU that I never saw on any other CPU (on youtube videos). There is this green small part you can see in the picture. I don't know what's that but it doesn't seem normal to me.
10-14-2019 01:34 PM
12-18-2019 12:32 AM
12-18-2019 03:26 AM
Equus Ligneus wrote:
Anyone having battery issues?
Mine seems to be discharging whenever it's not plugged in -- meaning after just letting the laptop sit turned off without the charger in.
Here's a picture of the battery log generated by my laptop,
Defect battery? Is it possible to order a new one and replace it?
