[GL702VM & similar] Solution to Performance issues / Overheating / Throttling / Whine
onjax
Hi guys, I bought GL702VM and was upset with its ability to handle games and high load. I had immediate temperature jump to over 85 jump and throttling / frame drops in games. So I decided to understand how to improve things, even though, I already lost my warranty due to my experiments, but at least I can answer for everyone, that:
- the main problem of this notebook is inefficient, insufficient cooling system with too thin fans, too small heatsinks, vent holes in a wrong places (aside, not above the fans).
To prove this, I first changed the thermal interface to liquid metal. That doesn't solve the issue. This proves, the thermal contact is ok, but heat dissipation is bad. Second, I ran stress tests with back cover removed - helped a lot, about 15-20 degrees off. The proves that air intake is wrong in this system.
I also removed an antidust tape with holes covering all the intake holes. That helped by around 5 degrees and also brought down air noise.
Then I came to idea of downvolting CPU and GPU, thanks to devs of ThrottleStop and MSI Afterburner, we can do this with relative ease.
The result: Fan noise reduced by half. Temp drop is huge. More speed due to ability of CPU/GPU to properly boost to max speed.
For your information - CPU is responsible for about 30% of heat, GPU - for 70%. So best idea is to undervolt the GPU, but for best results go for both.
THE GUIDE - CPU
Variant A - Install Intel Xtreme Tuning Utility
  • Go to Advanced Tuning tab and Change Dynamic CPU Voltage Offset to negative value (move slider to the left). -100mV is a good starting point. Leave Mode to Adaptive.
  • Apply changes.
My CPU holds -150mV well.
Variant B - Install Throttle Stop 8.3 or above
  • On main window click FIVR button
  • Under CPU Core Voltage move Offset Voltage slider to the left. -100mV is a good starting point. The lower value the less heat.
  • Click Apply. On the same window you can save settings to make them apply every time you start the app.
THE GUIDE - GPU
  • Download and Install MSI Afterburner 4.3 or above
  • In settings turn on Unlock voltage control and Unlock voltage monitoring
  • Close MSI Afterburner
  • Download my Voltage Profile for GTX 1060
  • Extract profile to some folder and then copy file to "C:\Program Files (x86)\MSI Afterburner\Profiles". Click continue as Administrator when Windows asks permission to write.
  • Run MSI Afterburner, click on profile 1 (out of 5). Then press Ctrl+F. (1 - least heat, but may be unstable for some... 2, bit more voltage etc till 5.)
  • You will see my Voltage Curve (screenshot). What you'll see that it's flat until 1050mv. that means. 1050 will never be used, so will never be used any voltage except 831mV @ 1860 MHz and below.
  • Click apply to test this curve
  • If this curve is not stable for you - edit it to your taste: Click on 831mV dot and move it lower, so that lower freq will be used for that voltage, and for 1860 freq next available voltage will be used. Etc. Work with leftmost voltage dots to make everything stable.
This curve drops heat of GPU by at least 30%, which is huge.
THE GUIDE - COIL WHINE
Workaround described here: https://support.microsoft.com/en-us/kb/975530
Perform only these steps as Administrator:
1. At a command prompt, run the following command:
reg add HKLM\System\CurrentControlSet\Control\Processor /v Capabilities /t REG_DWORD /d 0x0007e066
2. Restart the computer.
3. Run ThrottleStop v8.3 or above and uncheck C1E. Click save.
In theory, it will make CPU a bit hotter while system is idle, because it disables some advanced C-states, but i didn't notice that in monitoring app.
That solved like 99.9% of the noise, and in addition, disabling C1E in ThrottleStop solved noise issue completely.
1,122 REPLIES 1,122
Hey guys, i bought a GL702VM 8 months ago, and i usually knew that it heats a lot, so i'm trying the same thing as you guys. Since i added a ssd myself, i think i lost the warranty, so.
I bought a coolerpad, undervolted gpu and cpu and increased the range of the cooling fan, but i still feel that the computer heats a lot.
Playing OW on ultra i get 86 degrees, (usually with from the factory i tend to get 90+ on gta v)
I'm planning to remove the thing that protects from the dust, but i don't know, where i live its pretty dirty, if you know what i mean, 😛
I am not sure if this model has the same issues as the GL502VS, but here is a fix i applied and have had good luck with. CLICK HERE
I would be curious to know if this model has the same gaps..
I think i will test with the back cover off, then if is airflow issues, i will try to buy another one and make some roles in the right places..
I will also check those gaps, cdrshm, thanks 🙂
No problem at all! Looking forward to the results!
One thing that I'm going to try is this laptop cooler:
https://www.amazon.com/LC05-Cooling-Auto-Temp-Detection-Compatible/dp/B01NACVLWM/ref=cm_cr_arp_d_pro...
I think that this should probably work better than altering our laptops. The reviews are solid, can anyone comment on the efficiency of this if you own it, vs what we are trying so far?
It brings mine down about 3-4 degrees C
i was wondering, where would be the best places to introduce holes for a best airflow for this model?
At GPU fan extractor.
What are your temperatures when using that cooler? Is there a noticeable improvement? Thank you very much for those pictures, they're great! I appreciate it.
Zandor84 wrote:
MSI Afterburner should start up in the background with your last activated profile when Windows starts. XTU just save new profile then set and forget. So nothing to do there.
NBFC should start with windows if you tick the option from the cog window on the main screen and set to close to system tray. You should have a new system tray icon displaying CPU temp you can open the program from there. Set to enable and all to 100% before starting a game.
Edit: here is the config file that I promised. https://www.dropbox.com/sh/dty23nh7gffxr4p/AAAMm559SG3x24pr-geOHE3ka?dl=0
Copy XML into "Program Files (x86)\Notebook FanControl\configs" directory, Open NBFC, open dropdown menu in selected config panel select ASUS GL702VM_Custom, click apply, set enabled. Enjoy!
Isn't it dangerous to run them 100%?
my fans turn at 5200 rpm, it's too much I think !!
