11-26-2016
06:09 AM
- last edited on
03-05-2024
12:26 AM
by
ROGBot
07-05-2017 08:36 AM
pppttl wrote:
On other forums they say it's fine under 90, but it's depressing, I agree. You can use some tweaks to lower your temps:
1. Cut holes under the vents on the bottom cover. (this voids warranty, however you can order backplate replacements)
2. Update your bios (this makes a very significant difference)
3. Undervolt your cpu & gpu
4. Turn off Intel turbo boost when gaming
5. Use a decent notebook cooler (e. g. CM Notepal U3 Plus)
These tweaks are listed in order of impact on lowering the temperatures.
I use/applied 2-5. tweaks and was able to keep my temps under 80, usually in the mid 70's.
On the warranty: I think it depends on the country or the store you bought in, mine has 2 years. I think it should last at least 2 years with high temperatures but if you want to prolong it's life you can use these tweaks.
07-05-2017 10:36 AM
eliwood_next wrote:
Hi , if I only apply 2,3 and 4 (don't want to use notebook cooler or cut holes ) can I get decent temps on recent games ?
07-05-2017 11:00 AM
07-05-2017 11:04 AM
eliwood_next wrote:
by decent i mean around 80 °C in big cpu games like pubg.
btw , forcin fans to 100% is helping too no ?
07-05-2017 11:34 AM
07-10-2017 03:46 AM
StarJack wrote:
With -0.150mv on CPU, 99% max processor state, a cooler master notepal x-slim cooling pad and two Opolar LC06s my GL702VMK CPU sits at 65C while the GPU gets up around 72C in PUBG. I find most demanding games I play keep my temperatures within this range with this setup.
This is also with the latest BIOS 303 released today. The system idles around 34C with both Opolars set on 2.
StarJack
Sent from my SM-G925W8 using Tapatalk
07-07-2017 05:22 AM
07-08-2017 04:59 AM
Juicefulll wrote:
if after 2 years the laptop is still fine, ill start cutting holes. For now, i'd like my warranty.
Good to hear you had great gains in coolness with 2-5. Im really not interested in buying a notebook cooler for now. Maybe someone can sell me the product? How many degrees does it take off your processors? with vs without cooler? Also, how and for how much do you undervolt the gpu. Ive heard people say that it isnt worth it, you lose reletaively much fraps for the decrease in temp. Im very impressed to see you keep dem temps below 80. After undervolting the cpu im at around 85c 86c which already really feels bad, but much better than the 91c of before!
07-07-2017 01:39 PM
07-07-2017 02:58 PM
