GL553VE Automatic shutdown with Manual Fan Boost
Sid7886
I am facing an issue with my GL553VE laptop which shuts down automatically if you do a manual fan boost from the ROG gaming center..the laptop runs just fine if i keep the fan mode to 'Auto' but even with slightest increase in manual fan boost speed results in an automatic shutdown abruptly after 5-10 mins.. Also manually boosting the fan speed resuls in decrease of about 10-15 FPS while gaming ( i dont know for what reason). I also dont have Avast or any other antivirus installed which could be conflicting this..
I contacted Asus support and they asked me to update the BIOS..*
I have already uninstalled and updated nvidia to latest drivers, along with latest version of ROG gaming center (v2.03) and updated BIOS as well (v302), however it still doesnt help.
Is anyone else also facing the same issue with their laptops and have come across any solution for it?
Thanks*
113 REPLIES 113
Ysers wrote:
With Bios 303, I no longer have Gaming Center Manual Fan Boost (1-99%) shut down my computer.
Previously in Bios 302, manual fan boost was ineffective, ie. Max setting can still have a speed 2000-5100 rpm and 50% speed setting can sometimes have a speed faster than max setting.
It seems like the laptop shutdown because of incorrect chipset temperature. For example, CPU/GPU had temp around 55/45C, but Motherboard Chipset had temp in the 95C. Manual Fan Boost, because of incorrect setting, caused an increase in temperature, resulting Chipset temp to be 100C which would shutdown the computer.
After update, CPU and Motherboard Chipset have similar temperature of 55C.
Thanks for sharing your results with us.
Soulifyx wrote:
1. Open AMIUCP
2. Open AFUIWINGUI.... of your notebook type in AMIUCP
3. Choose Extract
4. Select the one that has @ROM as its ID
5. Give the file a name, whatever is fine then press Apply
6. You'll get a bin file, insert that into a flash drive and plug it in
7. Restart your notebook and enter BIOS
8. Choose advanced mode and enter EZFLASH BIOS
9. Choose your flash drive and then your bin file
Soulifyx, thanks a lot! This algorithm is not easy to guess.
Would you (or someone else, who has already done it) kindly help me with one thing: after "5. Give the file a name, whatever is fine then press Apply" i got a file, but it has no extension and is not recognized as .bin file (unless you type it in filename). Is it how it supposed to be?
Thanks in advance!
Thanks in advance!
Just type newbios.bin. It should be fine.
Thanks! 🙂
Hey man i just go for support page (https://www.asus.com/in/support/Download/3/927/0/3/mhTbsgvqzVP8ruaj/45/) and download the updated version of bios 302, but i checked downloaded file it still version 3/6/2017 (it should be 13/9/2017 or sometime around September). Any idea??:(
Nobody has a clue why so since last 10 days. I Guess 302 has cognitive bias.
Both 302 bios are the same. I did compare both 302 using ultra compare, both match. Use 303 if you want to update.
You have bios 303 file? Please send to me, thank you in advance!
BIOS 303
chainmaster
I solved the problem, i will come back with a post after i will test this out 🙂
