[GL553VD] Problem with GPU
lfcamara
Hi , got a problem with my Notebook. since december i started getting Blue screen (error power_driver_state_failure) so i decided to unistall both Nvidia GPU & Intel graphics Driver via DDU and reinstall the drivers on the Asus support. everything ok until now. today i turned on the notebook, tried to go to Nvidia control panel and it didn't open (Got an error that said that i didn't have an screen connected to Nvidia GPU), restarted it opened.
Then i started playing Fallout New Vegas, played for some hours, then when i closed the game and tried to open ROG Gaming Center to look to the CPU & GPU temps i found this.
70901
it almost seems that my notebook is not detecting the GPU
specs:
Intel i5-7300HQ
8GB RAM
windows 10 pro (Ver 1709, seems that this version has problems)
intel HD & GTX 1050 drivers are the old ones on the support page
14 REPLIES 14
Did you figure this out? It's happening to me again too.
Well im having same problem with gl553ve (1050 Ti). I ve sent my laptop to asus service to repair it. Now I got it back and again my GPU sometimes dissapearing, games freezing -_- I doubt ill buy asus again...
It's definitely a driver issue, guess we'll just have to wait for Asus to fix it 😞
I've tried every version of the asus provided drivers and they all do the same thing. Using Nvidia's most recent drivers off their website gives me BSOD so I'm out of luck there.
79660
hi, ive got this gpu problem with my gl553vd and dont know what to do, ive tried everything said in this thread but nothig, still no gpu :(:(:(:(
Simon942 wrote:
Don't upgrade to 305 it is not the version for your GL553(VD) it is the the GL553 but another number instead of (VD). Asus told me it was a fail that they had send it to Microsoft database. And they says thanks to me.
Don't upgrade.
Sympthoms you can get:
- Higher temps
- Inaccessible Boot Device (You need to reinstall the computer)
- Blue Screen Of Death
- Hardware failure.
Well, I do not face these kind of problems after I upgraded to BIOS 305. Somehow my Windows becomes more stable than previous BIOS, no auto shutdown or anything else
