Hello, I have a GL504GS. When i try to lower the maximum processor state in the power management menu it doesn't do anything. My cpu still runs normally. I've read to lower it to 99% but it doesn't lower my cpu speed. The only thing that makes a noticeable change is the power icon in the task bar if i move the slider. My only problem with that is i get 3 options nothing, half, or max. At half i run 2.1ghz. Is like to be around 3.6 any ideas why changing the percentage in advance power isn't making it slow down? Thanks
