09-17-2018 11:04 AM
01-07-2019 01:49 PM
Nickvassilakos wrote:
Please check the BIOS version that it is currently installed on your device and try to install the latest one.
Your product has pre-installed the ASUS utility WinFlash Version V3.2.2 that could be also downloaded from the below link
https://dlcdnets.asus.com/pub/ASUS/nb/Apps_for_Win10/Winflash/WinFlash_Win10_64_VER322.zip?_ga=2.184...
In order to check if you have the latest BIOS version you have to connect the Notebook with the charger and the battery level is more than 50%.
Then you have to download and unzip below file* on the “desktop
”Please “run” (double click on the icon) the utility WinFlash and load the already downloaded file.
*BIOS Version 307
https://www.dropbox.com/s/vgie6ip353qxcqj/GL504GM-AS.307.zip?dl=0
Please find below the related instructions
https://www.asus.com/us/support/FAQ/1008276/
01-08-2019 12:26 AM
durus.mihai wrote:
Has anyone updated to the 307 bios using this link? i want to ensure that is a safe link..
01-16-2019 02:14 PM
FULLMETALJACKET7 wrote:
Don't bother messing around with modded bioses unless you really know what you're doing. Be sure to have a proper dump of your stock bios and an spi programmer in hands, in case something goes wrong.
I mean, the link itself is safe, it's dropbox. The download is just a zip file with the bios file in it.
01-14-2019 08:10 AM
*BIOS Version 307
01-15-2019 03:45 PM
01-16-2019 12:27 AM
Someguy363 wrote:
Late on this, but just to let you know, I believe the problem was due to putting the laptop on a elevated surface for some reason.
01-16-2019 02:13 PM
That's a known issue. The thing is, why on earth placing a laptop on an inclined surface would affect its performance? I guess we will never know.
01-17-2019 08:14 PM
01-18-2019 01:07 AM
01-18-2019 08:18 AM
Nihck5 wrote:
bios 307 is now available on the official asus gl504gm support page.
... still waiting on that audio driver update to fix the issue of no sound after the laptop goes to sleep.
