01-29-2019
06:19 PM
- last edited on
03-06-2024
08:48 PM
by
ROGBot
01-31-2019 12:24 AM
RemSinus wrote:
Hello !
FPS DROPS :
I've been experiencing huge fps drops as many of us while playing videogames on my new ROG GL504GM for two months now.
After reading all posts and testing all the solutions proposed, i could finally solve these drops by :
- updating BIOS to new 307 version
- and/or (because i have tested this second solution at the same time i was updating the BIOS so i don't know which one solved my problem, or if both worked) i stopped using my cooling pad (who's apparently causing fps drops either by its slope or its interferences with ROG cooling system).
I don't know if it would work for you but apparently it worked for many people.
Try these two and hopefully you'll get rid of these drops ! (Even though heat remains quite high when you're playing games like PUBG, etc).
SOUND LOSS :
I was losing audio randomly as some people also experienced, after waking the computer back from sleep, but also simply by not listening to anything for a few minutes.
It all came back (until now) without problems with the new 1809 Windows Update.
Has probably been fixed.
I wanted to get these two problems with the solutions that worked for me in the same topic as i had to search and read for many posts to finally find solutions.
Hope it will help !
Now my problem :
FAN OVERBOOST : REQUESTING HELP
I canno't, from Gaming Center, change the Fan Mode. It is locked on Balanced : when i choose Silent or Overboost, it doesn't change.
As my computer's heat is still (and i guess will always be) quite high, i would like to set this mode to Overboost to increase ventilation.
Thank you in advance for any help on this last topic and i hope you guys can fix your fps and audio problems !
Thanks btw to you all for this active forum
01-31-2019 04:38 AM
02-04-2019 07:54 AM
02-04-2019 06:47 PM
02-06-2019 08:07 AM
