GL503VM Power Mode On Battery (while plugged in)
zanecz
Hey ROG fellas, hope y'all doing great.
Today my laptop decides that it won't detect my AC plug, even though it seems to run normally (games run at normal FPS, everything normal clocks) I experienced a shut down shortly after booting up a game though so I suspect it has to do with this.
Some images to explain my problem further:
84204
84205
As you can see, my AC cable is in, it's detected as the physical orange bulb lights up, however on a software side (windows 10) it's not detected.
I checked the BIOS, and it DOES detect when my AC is plugged.
The battery seems to stay at the same level while it's plugged in.
I suspect it's a software problem. I uninstalled the battery drivers and restarted my PC, to no results.
Has anyone run into the same problem? Do you have any suggestions? Thank you
0 REPLIES 0
