GL503 VM Drop FPS problem,save my son
cey8923
I bought ROG strix 2 GL503 VM, it always drop FPS when i play games and it is very serious. I have been checked it in the service center but they found nothing. GPU is functions well:
1. I have never saw my CPU reach 80% of usage. The highest is 60%
2. My GPU is GTX 1060 6GB, it seems like is GTX660 NVIDIA
Please help on how to solve or stop dropping FPS on my laptop
18 REPLIES 18
FULLMETALJACKET
Level 11
For troubleshooting, go to the windows power options > change advanced power settings > processor power management, set the "maximum processor state" to 95%. See if that brings the CPU temperature down. If it does, we will try something else using Throttlestop.
830288302983030 The maximum processor state to 100-95,but get the same test results
83031If you don't open the game and don't run big programs, its temperature is like this.
Enable GPU clock monitoring.
Also, the minimum state should be 5, maximum 95. Not 100-95.
8303583036Test Results Maximum 95 minimum5 and fan overboosts
My son only insisted for 1 minute, FPS 55 to 22.
gieffe22
seems like more VRM throttling on gpu side, is not a temp core problem.
The best thing you can do is send it again on service center, put those throttling screen on a paper and show them so they can test it like you explain. Probably they will change motherboard or heatsink/fans.
On the 3 time you send on service center you can force the VOICE with assistance and ask for refund or replace with another laptop.
If they didn't solve your issue in anyway, and they will not replace or refund your laptop, the last thing you can do is repaste your laptop manually with a good thermal paste lyke kryonaut (is very easy process once you saw how to open your lap) and apply a good thermal pads on vrm's that i think are throttling causing gpu to lower performance.
But try with service center gain!
EDIT
your son is gaming on DC adapter plugged in right? NEVER play on battery mode because laptop will throttle.
FULLMETALJACKET
Level 11
Yep. Seems like a vrm overheating issue indeed. RMA if it still under warranty, if it's not, repaste.
I bought a piece of equipment, I feel it may have an effect, wait until I get the test results for you, now I want to ask, my computer is in a casual state, the CPU temperature reaches 58-60, the GPU is 57, normal?83096
Should be around 50C for both GPU and CPU while browsing the web.
