08-09-2017 12:37 PM - last edited on 03-05-2024 10:06 PM by ROGBot
08-09-2017 11:22 PM
link626 wrote:
6 months old, new laptop, always plugged in.
I was encoding a video , cpu and gpu were hot, but not overheating. Turboboost was coming and going, and cpu was staying under 99C.
and then all of a sudden, the laptop shut itself down, and the battery light was blinking orange. Again, I was plugged in.
Battery was completely drained even while always plugged in.
I turn on the laptop again, and Windows says my battery is at 97%, not charging. But the battery light was still blinking orange.
Ok, so I have battery power?
I pull the power plug, and the laptop lost power immediately.
Nope, no battery juice.
I plug the power back in, and Windows says battery is 0%.
so,
If I'm always plugged in, why did the battery drain to 0% ?
Did Asus screw up the battery management and calibration software in the bios, if there is such a thing?
By design, the battery goes up and down between 95-100% while plugged in. Maybe it charges 1% less each time, 94>>99, 92>>97.... and so forth, until the battery is completely drained, and Windows doesn't know it.
If it charges 4% and drains 6% repeatedly, eventually it will use all the battery juice.
Either faulty battery hardware or software.
08-10-2017 01:27 PM
08-11-2017 05:18 PM
