10-14-2012
03:01 PM
- last edited on
03-05-2024
11:22 PM
by
ROGBot
10-14-2012 03:50 PM
10-29-2012 03:53 PM
10-29-2012 06:09 PM
10-29-2012 07:58 PM
10-29-2012 11:46 PM
10-31-2012 06:47 PM
10-31-2012 07:38 PM
11-01-2012 11:14 AM
rewben wrote:
@MUPiSz, please check out here for a possible solution for you. it seemed that @g75owner has the solution to his issue but maybe he will put down the exact steps.
04-10-2014 01:02 PM
One more thing that makes a significant difference is to go to Device Manager and open the propoerties for the Network Adapter, click the Advanced tab and disable Large Send Offload (IPv4) and enable Large Send Offload v2 (IPv4). You can also try changing the Flow control from RX & TX to disabled and check, if no difference re-enable (because it is the default) and also try disabling the Interrupt Moderation and testing.
