G732LW MyAsus app reports battery and power adapter problem although...- solved?
KITT_2013
MyAsus app reports battery and power adapter problem although the laptop charges fine and the battery works fine. I want to mention that randomly while using the pc, a pop up message appears that says the power connector isn't plugged in properly although the charging is fine and not interpreted or anything. Also the connector is plugged in properly.
2 weeks ago when I checked myasus app, evey hardware test passed and now randomly, battery and adapter issue. Why? and everything is working fine...
20 REPLIES 20
KITT_2013
The laptop model is G732LW
I have the same issue. battery and adapter errors are reported. I tried to charge my battery up to 100% and tested it again, this time, battery became OK but the adapter still failed.
i have problem too battery and charger faiiled but all working fine
KITT_2013
Asus should fix their software...
Hi, like all of you for me was the same after the latest update, anyways my Battery charges perfect!, what I notice is now time to time Armoury Crate select Windows power mode connected or not. I think there must be an issue between what Win10 reports and what the software tool expects as a good result...I don't know. Please fix this in the next update.
KITT_2013
Also when launching certain games or game launchers, the sleep setting and brightness of the laptop change to never respectively 100%. Any idea why?
KITT_2013
I can confirm that the issue appeared also on my secondary laptop, a non ROG one, after updating the asus system control interface v2 to the latest version.
Blake1
Dear all,
May I double check if your MyASUS App is 2.2.35.0?
If so, please kindly wait for the next update of ASUS system control interface driver and MyASUS APP.
KITT_2013
It is. Any update on the fix?
