01-03-2021 05:51 PM
02-21-2022 05:11 PM
omkar255t wrote:
I am also facing exactly same issue with strix hero 3. The problem is that the charging pin has some plastic on the very top of it, it melts when we are playing games and stuff, hence the loose connection. I fixed it by changing the charger (It was loose even when doing normal stuff which won't overheat laptop and the charger pin). Now same issue is coming with new charger, it is so frustrating. I always use cooler whenever I am using laptop and still I got this issue. Now I am waiting for 230W pd chargers to come into market cause they don't have that plastic thing on top of them, till then I am just adjusting my pin (Not helpful at all, but you gotta do things like this )
02-24-2022 02:11 PM
Preynolds2 wrote:
Have you found out anything ?
I have the same problem.
Ive been thru several chargers and they have all done the same. They work at first but eventually get super hot at the plug (where it plugs into the laptop) some clear silicone even melts and oozes out of the end.
02-25-2022 07:16 AM
volors wrote:
Just a question, all the chargers you bought were they all ASUS or did you tried any other chargers which are compatible or made for G731 series like there are some available on amazon.
03-24-2022 05:19 AM
Preynolds2 wrote:
I've tried both.
So far 5 total.
Seems it's not a charger issue. Hopefully a port issue like stated above.
02-21-2022 05:20 PM
07-02-2023 07:42 AM
This post was a while ago, so it is possible it was resolved or you got another laptop by now.
Just curious to see if you bought the 230W adapter and if it resolved the problem?
XanaduQ
02-21-2022 07:54 PM
Jimbo93 wrote:
I suspect its a broken jack. My old G73sw adapter jack would break quite easily and lead to a similar issue.
02-21-2022 08:15 PM
Preynolds2 wrote:
Where do you get a broken jack fixed?
04-30-2022 04:33 PM
