11-02-2020
06:30 AM
- last edited on
03-05-2024
07:05 PM
by
ROGBot
11-02-2020 11:54 AM
baczeks9696 wrote:
Hello,
I've been battling this issue since late august, to no avail.
Quite often the armoury crate will not show the CPU fan rpm reading, and when this happens aforementioned fan will behave in very weird way (ramping up to about 80%, while the CPU is idle, and after 2-3 minutes backing down to normal rpm, and repeats this cycle constantly). GPU fan always shows reading and does not behave in this strange way. Also the cpu stat readings tend to break as well.
After using the pc for some time the reading will come back, however i don’t know what triggers it. Also when the reading is present the cpu fan behaves normaly as it always has been. Reinstalling armoury crate fixes the issue imediately, but it often comes back again in matter of days. Also the windows updates tend to break it too. I've tried multiple BIOS versions, and all are susceptible to this issue. It feels like their is some kind of conflict between ASUS fan controlers and windows.
Has anyone run into the same issue, or am I alone in this one?
Best regards 🙂
11-02-2020 12:45 PM
KorosuKivy wrote:
what preset are you using?
Windows/silent/performance/turbo?
have you tried to reinstall armoury crate?
11-02-2020 05:26 PM
baczeks9696 wrote:
Hi, 🙂
It happens on every preset, and I've reinstalled the AC countless times unfortunately.
Best regards
11-06-2020 04:50 PM
KorosuKivy wrote:
If a Windows system Reset doesn't fix it if it's still under retailer warranty return it. otherwise, Asus will just say "send it into their RMA centre"
12-24-2020 12:54 AM
01-07-2021 11:14 AM
Blake@ROG wrote:
Hello baczeks9696,
We have released solution for such issue.
Please kindly reboot the device, and after reboot, please DO NOT open Armoury Crate.
Then connect to internet and wait for 15 minutes.
Then go to C:\Program Files\ASUS\ARMOURY CRATE Service\ArmouryCrate.InstallationInformation.exe to run the exe.
Check if "ArmouryCrate.ThrottleGearMergeModule" has been updated to version 3.2.5.4 or latter.
04-07-2021 01:17 AM
Blake@ROG wrote:
Hello baczeks9696,
How everything? do you still have the issue?
