Fans speed stuck after load - ROG Strix G16 2025 (G615JPR)
aalair04
Good morning, I have an Asus ROG Strix G16 2025 (G615JPR), and for the past two months I´ve been having issues with my fans.
The problem is that when I run a heavy load in Performance or Silent mode, for example, gaming or anything that makes the fans ramp up, after the load ends and the CPU goes back to normal speed, the fans don´t slow down. Theye get stuck at a higher RPM than usual for that temperature and never recover their proper fan curve. Sometimes they stay at very high speeds indefinitely.
The only temporary fix I´ve found is switching between modes, for example, going from Performance to Silent and then back to Performance, so then fans reset to normal speed.
I would really like to fix this issue because I prefer to keep using Armoury Crate, but I´ve been considering switching to G-Helper if I can´t solve it.
Please, I would really appreciate your help. Thank you very much.
eXplode
Try to reset the bios
Turn OFF the laptop and plug it in the charger
Hold the power button for 40-60 second's
Then restart and test
