Fan Issue G16 G614JV. CPU/GPU fan 0 rpm only mid fan running after wake from sleep
xxmywxy
The CPU and GPU fans are working properly. BUT, once after waking from sleep, these two fans would NOT be wakened no matter what I did. MyASUS can run the diagnostic test and tell me fans are ok. But they will not continue to run to keep the temp low. Even the CPU reaches 90+ C, the CPU fan will not run. Only the mid fan is running.
Updated BIOS and Armoury Crate. Now I am using G-helper. This issue keeps occurring.
Only turn off the laptop then turn on could make things back to normal. Restart wouldn't work.
Someone help me 😔
0 REPLIES 0
