fan in my G53SW suddenly sounds like a diesel engine
bitt3n
It's about 4 months old. I am wondering if this is something I can repair/replace, or if I have RMA it.
6 REPLIES 6
dstrakele
Level 14
Could be a bad bearing in the fan. How comfortable are you disassembling/assembling laptops? Ever done it before?
G74SX-A1 - stock hardware - BIOS 202 - 2nd Monitor VISIO VF551XVT
yes that should be no problem assuming I can figure out what part to order. the fan in question appears to be located at the far right rear of the unit, although I have not yet opened it to investigate.
dstrakele
Level 14
You may also find that something is contacting the fan, creating the noise. See http://forum.notebookreview.com/asus-gaming-notebook-forum/616055-how-disassemble-g74sx-reduce-speak...
You can probably get the part number from contacting ASUS. What you have to decide is - do I want to void the ASUS warranty by attempting this repair?
I found a video for disassembly to add ram and 2nd hard drive, and I have the unit disassembled this far, but it looks like further disassembly will be a bit more complicated. Is there a good video on full disassembly? Ideally I want not to break something AND void warranty AND not fix fan.
dstrakele
Level 14
Did you see http://www.youtube.com/watch?v=TdQi2GMQRu8?
yeah, that's OK but the angle is terrible, mostly you see the side of the case and his arm. FWIW this is what my fan sounds like
http://www.youtube.com/watch?v=KUntoP31UdY
any ideas whether this the bearings or something rubbing? The latter seems unlikely because I haven't moved the machine in weeks.
