Display issue, damaged internal display, not installed OS
biohardware
Hello,
I have an ASUS ROG STRIX G G531GU,
the display is completely broken, there is a backlight!
There is no system on it, I put a new m2 ssd in it!
I connected a usb keyboard,
if the internal display is plugged in, it responds to pressing the num lock button, so the machine does not freeze!
If I pull down the internal display, there is no response to the num lock!
I connected a monitor via HDMI, but I can't enter the bios either, or I can't see anything, or even if I insert a Windows installation USB, the external display doesn't respond!
Can you help me what to do?
Thanks
6 REPLIES 6
Bogus5
Level 12
Try connecting your monitor/TV via the USB-C/DP port (number 4) on the back of your laptop.
havent usb-c port! just a HDMI
On the contrary, DP is Display Port. 😁
no, its havent USB-C or dp port!
3 USB a
1 jack
1 dc charging
1 hdmi
1 ethernet
thats all 😄
Bogus5
Level 12
