battery drain while plugged in and gaming, normal?? asus rog scar strix 2
packersfan036
hi everyone, im noticing small amount of battery drain while plugged in and gaming. I replaced the original 180w charger brick with a 230w and still drains. now with the original charger I was having major issues like when gaming the laptop was freezing in game and booting me back to the desktop and in some cases freezing then blue screen. anyways after I replaced the charger that seemed to stop, but the battery draining while gaming still seems to happen. my laptop is a strix scar 2 i7 8750h cpu 16gb of dual channel ram 2666 MHz, and a gtx 1060 6gb video card and a 17" screen. thanks everyone.80307
11 REPLIES 11
FULLMETALJACKET
Level 11
It is normal if it doesn't go below 95%.
packersfan036
I cant remember I think it went down to 95 or 94 percent
That's normal. Don't worry about it.
why is it normal? just curious.
To prolong the battery life. Keeping the battery at 100% charge at all times can damage it over time.
ok cool thanks for letting me know. I just got through playing ww3 for like 15 or 20 minuts seemed to drain battery only 1% not bad. I think this is normal, what do you think? im using my 230w charger not the 180w which is garbage.
Perfectly normal. Mine goes down to around 95% at times, since I got it a year ago. Right now it's sitting at 96% (plugged in, not charging) and I just booted up.
do you notice a drain while gaming? and if yes, how much?
