Armoury Crate Problems, problems
ahkedzior
New Asus ROG Strix SCAR 18 G834JZR-N6036W laptop. Armory Crate installed and uninstalled many times. Nothing helps. It works properly for 2 days at most. I leave everything without interference. And the problems begin. First it doesn't see the keyboard to be backlit. If he can see it, then Aura Sync isn't working this time. I care about intelligent backlighting. after a new installation (as I wrote) it works for a maximum of 2 days. Nothing helps, rest of the application, updates. Nothing!
1 ACCEPTED SOLUTION
Accepted Solutions
eXplode
Download Ghelper i will make really good work i switch to it
5 REPLIES 5
eXplode
I found G-helper and installed it. Nothing helped.
The notebook started with it and the keyboard backlight still works as expected.
Aura doesn't sync. Especially the intelligent backlight does not work.
Have you installed all drivers from the official website and when you uninstall armory crate have you used the uninstaller tools also you can make post in armory crate section in this forum
I always install drivers from this website only. I used Armory Crate Uninstall Tool v. 2.2.7.0. I reinstalled (several times). After 2-3 days, Armory Crate goes crazy and does not work as it was set.
ahkedzior
I didn't find Ghelper.
Where can I download?
