07-20-2025 08:04 AM - edited 07-20-2025 08:16 AM
Hi all
I have had this laptop for a few months now and when I play a demanding game like Doom The Dark Ages or Dune Awakening the audio glitches every now and again. When I use headphones like my Arctis 7P+ the sound will get progressively worse the longer I play, almost like interference or digital breakup. Headset works fine on another machine.
Bios is up to date, all drivers are up to date. Any sound processing is turned off like spatial audio and atmos for headphones.
Someone suggested running Latency Mon and run my game, soon as the game starts I get the red warning as pictured.
Is this a hardware issue of some sorts, anyone shed some light ?
Thanks
Solved! Go to Solution.
07-26-2025 02:46 AM
I got a fix off reddit that worked in my case for the bad audio on my headset.
Go to device manager, USB controllers, and turn off "allow the computer to turn off this device to save power" on all of the devices that had this option and my sound was fixed right away.
07-26-2025 02:46 AM
07-27-2025 05:20 AM
I have a same problem too. But your solution did not help me unfortunately.
07-27-2025 09:11 AM
Sorry to hear it. Which issue are you experiencing? Bad headphones audio or in game audio issues from the system speakers? Or both.
08-18-2025 11:28 AM
Hi friend have you tried thw latest bios updates ? Although the usb thing i mentioned above fixed the headphones issue is still had occasional game audio jamming up.
Bios update fixed this for me. Maybe related and worth a try
08-19-2025 02:34 AM
Hi i install latest bios and install ne driver for something about intel. It fixed now thank you 😄
08-18-2025 01:34 PM - edited 08-18-2025 01:39 PM
This is the latency on my laptop and to get latency like this you must do a lot of things and optimizations .... https://youtu.be/hPl1Wbmfu9o
Chekc this also watch full video
