10-16-2025 05:31 AM
i just got the new G16 with the 5070Ti and love everything about it except for the POWER PLUG it is so big and sticks out the left side and im afraid that it will break something. Ive been looking everywhere to find a Right Angle / 90 Degree adapter for this plug and cant find anything anywhere. I did find a Lenovo rectangle power plug that might work but not sure and was wondering if anyone here has looked for something like this? i know there is the PD port that supports up to 100 watts and 90 degree cables are easy to find for PD so i might try that route only concern is it only supports up to 100 Watts and when im day trading i dont know if that would provide enough power. any help would be great thanks
10-16-2025 05:58 AM - edited 10-16-2025 06:00 AM
Use the power supply supply by unit. any other thing can cause damage to the unit. Some units have Typec charging PLEASE, DO NOT use this to charge OR use both at the same time to charge ONE or THE OTHER. The 100w type c is for light thing to maintain NOT to charge that nis the job of the charger ( 240W AC Adapter,) . MOST UNIT and in fact ALL laptops that support a extra 100w type c is NOT to plug a charger. is mot to plug a power bank. PLEASE check manual of the unit and OR contact asus support . But the manual is clear.
Any other thing user say ON Those units the answer is on asus support and or follow my recommendation.
