05-02-2025 12:19 AM
I recently purchased this monitor and it has two key issues that were not covered here which people should be aware of. 1. The grey uniformity is substantially worse in dark scenes on 360hz mode vs 180hz or lower. I'm not sure why this is, but it's pronounced enough that I've decided to just run it at 180. 2. The OLED care schedule is bugged in the firmware even as of the latest update, it does not reset the timer correctly and will pester you to run pixel cleaning even if you literally just ran it 5 minutes ago (I have it set to 4 hrs). It seems like the timer doesn't correctly respond to the most recent cleaning event, and only cares when it last popped up. This is pretty annoying, but worse yet it makes the monitor run pixel cleaning much more than intended. I'm really hoping they fix this one in the firmware as I worry it threatens the longevity of the panel Is it possible to have an update in this regard to correct these problems? thank you
