PG32UCDM FIRMWARE (Advanced HDR controls & anti-OLED flicker)
Sriarno
Where is the new firmware update with advanced HDR controls & Anti-OLED flicker and many other features for PG32UCDM?? Almost 6 months of no new firmware meanwhile other models receiving every month once, So with this should we need to conclude that ASUS ditched UCDM model to boost up UCDP sales? Come on guys still its not a cheap product anywhere it costs almost equally as much as high end PC. Is this the current state of ASUS support system? Seriously guys this is gonna be my last ASUS product. ASUS is nothing but a cash grab brand and that’s been proven once again. @Aureliannn_ROG
13 REPLIES 13
carb
Yeah, must admit I am equally disappointed. Still have bugs on mine like not waking from sleep etc, basic stuff that's not yet fixed.
Jigovsky
I'm also waiting for an firmware update to come out.
carb
It's really bad. Basically a broken product in it's current state. Considering an RMA.
dkflint723
I also mentioned this in another topic, but I've found that disabling and re-enabling VRR through my monitor substantially reduces the flicker effect. It's not an ideal permanent fix, but it works for me. Ideally, a FW update will eventually come out to fix this. @Silent_Scone any word on a potential fix for us?
Jigovsky
Still no new firmware.
Jigovsky
I thought there would be something released by Christmas. Unfortunately.
dkflint723
I'm not sure if any of you have tried this yet, but this has worked for me to limit my VRR flicker.
https://www.displayninja.com/what-is-vrr-brightness-flickering/
https://www.monitortests.com/forum/Thread-Custom-Resolution-Utility-CRU
TLDR; use a program called Custom Resolution Utility to change the VRR range from 48hz - 240hz to 76hz - 240hz. Then, use a frame limiter on games that skirt the line and lock them to 65FPS. By doing this, it will significantly reduce the flicker effect.
dkflint723
If you guys use ASUS DisplayWidget Center, it has a new feature to download FW updates. Currently it's trying to tell me there is a MCM109 FW for the PG32UCDM. But when you actually look at the file, it seems like the installer is for the PG34WCDM. So be careful if you try to install this.
I have no such option for the firmware update, and i have the same monitor.
14900k
Asus Z790 Formula
2x32GB Corsair Dominator Titanium 6600 CL32
Asus Rog Strix 4080 Super
