PG279Q stuck at 120Hz and terrible flicker using CS:GO (GTX670 SLI)
MarT2
Hello,
I bought a PG279Q yesterday, and I can't set it to 144Hz. I only can go up to 120Hz, on normal, gsync, or ULMB mode.
I'm using the latest 361.43 nvidia drivers, and the latest monitor driver, connected to a GTX670 SLI on a W10 pc.
I can't create a custom resolution too, I don't know why!
I know that with this graphic card can't go up to 165Hz, but why not 144hz? It stuck ever at 120Hz. I don't know why, if my graphic card is 144Hz capable and the monitor too.
54447 54448
I have too a terrible flickering (screen is turning black for a few ms all the time) when running CS:GO on the PG279Q at fullscreen, and have any window open in the secondary monitor. It only happens when I have enabled GSYNC in global config, and ULMB enabled on CS:GO config (NVCP). If I disable GSYNC, it works OK, and if I disable ULMB on CSGO, it works OK too. How can I solve it?
Thanks in advance!
Braxos
You need a 9xx card for higher hz
phatec
You need to use a Display adapter with a higher quality graphics card either 970, 980, Titan X to benefit from the G-Sync 144-165hz.
Please disable your G-sync as this is not compatible with your current graphic card.
Kotronas
Disable the OC from pg279q and check if you can get at least the 144hz with the 670. But a 9xx is recommended for maximum OC .
