07-14-2017 07:04 PM - last edited on 03-05-2024 10:12 PM by ROGBot
07-14-2017 08:15 PM
07-14-2017 08:42 PM
Korth wrote:
You only need one video input connected. DisplayPort is better than HDMI.
If you connect both then you'll need to switch between DP/HDMI output on your video card (through software), you may need to switch between DP/HDMI inputs (on your monitor) if it doesn't autodetect.
Better to disconnect the one (ahem, HDMI) you're not using and only use the other one (ahem, DP) which offers better performance and quality. Multiple output and input types are provided only to increase compatibility when pairing GPUs/monitors which don't support more advanced connectivity, or for output to multiple displays, or for switched input beween multiple video sources.
You shouldn't need to switch input types at bootup. Although (now that your GPU drivers have detected both types) you may need to explicitly set the one you want active, you even need to uninstall/reinstall GPU driver software, you probably have to reboot once or twice for your preferences to persist.
07-14-2017 08:46 PM
07-14-2017 08:54 PM
07-14-2017 09:21 PM
Korth wrote:
Page 3-4 of this PG279Q User Guide shows how to change the "Input Select" setting with the On-Screen Display (OSD) Menu.
07-15-2017 05:22 AM
07-16-2017 02:55 PM
Korth wrote:
I don't know what the PG279Q is supposed to do automatically. Nor the XB270HU. Never used either.
I would expect it to autodetect changed signal source when powered on, and to remember the setting for next time. You'll figure it out through the OSD and know more about that monitor than I do, lol.
An underspec and uncertified DP cable might cause strange errors, though I doubt it, especially if it worked perfectly on another monitor.
07-16-2017 08:09 PM
