03-19-2018
03:42 PM
- last edited on
03-06-2024
09:03 PM
by
ROGBot
03-19-2018 08:09 PM
03-20-2018 06:23 AM
MarshallR wrote:
Hi Ashus,
You said you tried disabling G-Sync but it still happens when it's on/off? Because G-Sync only works in full screen mode not windowed. So alt+enter into windowed mode would disable G-Sync.
Have you tried different DP ports in the GPU?
Have you tried a different DP cable? This eliminates a connector issue.
If possible, can you try a different Nvidia GPU with G-Sync - that will eliminate the GPU possibility.
If all that is not the issue, then it looks like the monitor itself is the issue. It's difficult to determine if it's intermittent like you say.
03-20-2018 01:54 AM
03-20-2018 06:26 AM
Silent Scone wrote:
Try the above most notably changing the DP cable, however also check that your desktop refresh rate matches that of your in game one.
03-20-2018 08:00 AM
03-25-2018 06:46 PM
Leonidas44 wrote:
I had a similar bug with my Pg258q , especially when i turned the monitor off and then off (gsync couldnt engage back again and my led was white) , entering a game would end up losing the dp signal and the led blinking orange.
Disabling the DisplayPort Deep Sleep within the OSD -> System Setup ->Displayport Deep Sleep solved this problem and every other bug!
04-06-2018 01:35 PM
