Monitor failing help XG27AQDMG
Bornagain07
I got this OLED monitor about a month ago. Everything was working fine but came home the other day and it has started distorting lines across the screen flickering on and off goes to black screen then back on. I updated the driver's that seemed to fix it for a day. I came back home this morning and there was distorted lines on the screen without the PC even being on to give it a source. I saw there was another graphics update and updated. The firmware hasn't had an update since 2024. I tried changing the display port to HDMI didn't help my second monitor is working fine. I tried using the port the second monitor was using same issue. Not sure what else to do.
Bornagain07
